kamkar
- Oct 11, 2013
- Denmark
- 10 years, many dashcams
Hello. I have got a mini dash camera with some problem. There is 32Gb sd memocard installed.
Camera takes 5 minutes footages on it (385Mb each). However there is enough space the media player can read only 29 files.
The rest is "unknown media file" for media players. It makes MOV files. There is no any option in camera settings to
change size files or something...I have formatted all my class 10 SD cards.
If you have any advice I appreciate that.
Regards,
Laszlo
Only way to get smaller files with the same 5 minute file size is to lower the bitrate, but that will impact image qualety in some degree.
You can allso change fron the 1080 i assume you use now to 720p resolution, but thats not recomended either.
If you just want more files you can change to 3 minute file size.
The remaining files on your SD card might be GPS data files, or just video files thats corrupted and if so then media players cant play it.
If it is broken files you have taking up space, then registrator viewer might be able to fix them for playback, all you have is to tell the software where a simmilar working file is ( recorded on same camera with same parameters )
