PeteTheGreek
OK as an electrician let's explore the options.
1/ plug into cigarette lighter socket
2/ hardwire into a switched supply
3/ hardwire into permanent supply
All these options have issues.
First we plug into a cigarette lighter socket. This takes up an important socket from other uses. It's untidy and turns off when ignition is of.
If we hardwire into a switched supply, then it's no different to plugging in the cigarette lighter, but frees up the socket £70 fitting charge to free up a socket).
The final way is to hardwire it into a positive supply. With this the cam receives power all the time. Sounds like a great idea.... WRONG.
Doing it this way runs the risk of flattening your battery (unless you install some zener diodes). Also, the cam won't know when your parked up and so it will keep recording, with the screen on. Also, the battery life will depreciate from the permanent non stop charging (so the techys in the main store selling nextbase tells me).
So what's the best way of installing a dashcam. In all honesty, there isn't one. I took the liberty of visiting a main seller of nextbase. I asked the question. I won't even mention the answers as they were all incorrect.
So, I have two dashcams. One front, one rear. I opted to simply plug in a large powerbank into the glove compartment. From there, I fed my front and rear cams. I then set the screen savers.
It works a treat but in all reality the best dashcams are professionally fitted ones with a separate DVR in the boot.
In all fairness, £100 a year is not a fortune to pay to protect your insurance. So even if I have to replace them every year, it's worth the spend. One (blamed on you) crash could cost thousands on your policy so the onus of proof is on you.
