JaseQ
- Sep 18, 2015
- United Kingdom
- Blackvue 650 2 CH
I have the Blackvue 650 2CH dashcam which I have owned since September and it is hard wired into my vehicle using the Power Magic Pro. I have had the dashcam replaced a couple of times due to various issues I have come across and it was recently replaced so that I could utilise the Cloud facility. The dashcam is running the latest firmware 2.001.
The issue I seem to be having now is that almost on a daily basis the dashcam gives the audible message 'WIFI FAILED' and the only way which I can rectify this is by pushing the button on the side of the unit which formats the SD card which has the desired effect until the next day or sometimes until the next time I use the vehicle.
I have no idea why this message is becoming so regular but it does get annoying having to format the SD card each time the WIFI fails. Is this an issue with the firmware or the dashcam itself?
The other problem I have from time to time is sometimes when driving the dashcam will shut down for no apparent reason. Again is there anything which could be causing this issue?
