Windscreen sucker problem on tint dots
GambleGold
India
Hello, my dashcam came with a suction cup mount. The best place is in front of the rear view mirror, however the windscreen has a patch of tinting there, made up of tiny raised dots. So the suction does not last for long and the whole thing falls off. Is there any kind of material, substance etc which will enable a lasting seal? Is there some other way to attach the dashcam?
Find some high quality double-sided tape, preferably black. Peel the paper from both sides then stick one side to the suction cup. Now attach the suction cup as you would normally. End of problem.
Hi, thanks for reading and replying.
It is a Next Base Base dash cam 112.
I'm favouring the black double sided tape solution so far. Thanks
You can get a 3M disk that you can stick to the dot area, then suction the mount to that. Search for 3M dashboard disk. Make sure to get the ones with the red backing. There are different sizes as well.
Thanks for the specifics. I'm assuming it can be removed later, if need be, and not damage the tinting. Correct?
Hello,
We have designed a mount with a 3M adhesive pad on it instead of the vacuum suction mount.
If you contact our technical support at support@nextbase.co.uk we can arrange an adhesive mount to be sent out for you.
