AlFromCO
Hi All!
Just wondering if anyone has any suggestions as to what to do with my hardwiring issue - the BATT function (for parking mode) of the hardwire kit works just fine (so ground line and BATT line are good), but ACC doesn't (device doesn't start). I have 12.8 volts measured at the ACC wire (and when I switch that same power to the BATT wire while keeping ground connection the same, device starts). I've got a Wolfbox G840S. The ACC wire is fine (not cut or abraded). When I test the camera to see if the ACC functionality is good by using the supplied cigarette lighter ACC power port (instead of the hardwire kit), the camera starts. Can't figure it out.
Thanks for any thoughts you might have.
