shunter293
- Apr 6, 2014
- Derby
- United Kingdom
- 2 x 0801, 0803, 0806, Thinkware F750
I have had my 0806 with two 64Gb Samsung Evo cards since February 2015 in the front of my car which replaced the 2014 0803 with a 64Gb Samsung Evo card which is now in the rear window.
After being on the forum for some time now I have noted that the majority of postings appear to be problems or complaints about the 0806 but my 0806 has worked perfectly since new with the exception of the card switching problem.
I appreciate that it will be people with problems or faults that will be the main users of forums and we will therefore never truly know the extent of the number of working cameras and this may well be a factor in putting people off purchasing this camera and the same will probably apply to any other model of camera.
The car is used daily and usage varies at between 45 minutes and 6 hours each day and the GPS locks quickly every time, focus is spot on, the battery is still going strong, the micro SD cards are still working as they should and have only ever been formatted once as Fat32 at first use, no power connection problems and in fact I can't think of any failure of any sort at all and the camera only comes out when I need to access the card to copy any files off otherwise it stays in the windscreen.
For that matter the 0803 has always worked as it should and still does.
Both cameras are powered from a dual USB cigarette lighter supply when the ignition is on and when the ignition is turned off they automatically switch to a power bank for power which is capable of running both cameras for about 20 hours if necessary but can be switched off individually or left running until the (variable) timer turns them off. When the ignition is switched on again the cameras are again powered from the car supply and the power bank is also charged up again.
I suppose now that I have put this in writing it may be the kiss of death but hey-ho maybe I have been lucky.
