Autoexec.ash scripts do work with the Yi4K, just not as well as they do for the original Yi
If you create a autoexec.ash file in the root of the sd card and switch on the camera it will execute the commands listed in the file on bootup.
Unfortunately there are not many documented commands and a lot of them either do not work or get overwritten when you use the camera.
So you can set the camera to automatically start recording video as soon as it has booted up by having the following command in the file:
t app key record
this will simule the record key being pressed and the camera will automatically start recording video on startup be careful though because if you are in a photo mode when you switched it off it will go a bit funny.
Another useful one is to start wifi automatically on bootup, this is great for the people that have cracked their lcd screen and cant manually turn the wifi on. The command is:
t app key start_wifi
to turn off wifi, you can use:
t app key stop_wifi
other t app key commands are:
key Usage: t app key <key>
Key list:
up
up_rel
down
down_rel
left
left_rel
right
right_rel
zoomin
zoomin_rel
zoomout
zoomout_re l
set
focus
focus_rel
shutter
shutter_rel
record
mode
menu
power
del
stop_wifi
start_wifi [ssid] [name] [5G/2.4G]
poweroff [time]
pc [help]
up_rel down down_r
If you edit any of the firmware.bin files you can sift through the entire file and find references, here are some I have pulled out.
I have tried a few and they either dont work or crash the camera, but here you go have a play and report back here if you get any luck
Stillrawcap Usage: t app test enc stillrawcap [Cmpr][DumpItuner] Cmpr:0 : Normal Raw, 1 : Compress Raw. DumpItuner: Enable dump ituner or not
videorawcap Usage: t app test videorawcap [RawCompress][Number][EnableFaseCapture][EnableYuv] RawCompress:0 : Normal Raw, 1 : Compress Raw. Number: Capture raw number. EnableFaseCapture: Enable fast capture or not EnableYuv: dump yuv or not
Usage: t app test enc<option>
Test option list:
stillrawcap
videorawcap
Video only AV photo preview video preview still chg_res ----vf----
t app test beep play <path>
t app test beep set_vol <vol>
t app test onoff [0/1] [time_to_poweroff] [time_to_wakeup]
t app test dual_stream [1|0]
t app test vf on
t app test vf sw
awb_setting [t_app] change awb mode to %d, modetype = %d chg_preview %s[t_app] you are now in %s
[t_app] change iso to %d [t_app] change shutter to %d scene_setting [t_app] mode : %d, change scene to %d crop_file [t_app] crop file %s: from %dms to %dms, output file: %s video_rot Just supply 180 rotation MCTF_off [t_app] turn %s MCTF sensor_flip [t_app] set sensor flip %s EIS_enable SS_enable [t_app] set SS %s OSD_rotate [t_app] set OSD rotate to %d degree single_ituner [t_app] %s dump iTuner file in SingleCapture b_shutter_setting [t_app] set b shutter to %f s, iso to %f max_shutter_setting [t_app] fix max shutter to %d enable_rawcap slow_motion enable_CFA set_EIS_range dewarp_support = %d eis_support = %d support_auto_low_light = %d video_rotated = %d show_temp dbg_dsp_event AmbaDSP_EventDbg = %d Usage: t app test dbg_dsp_event [0|1] sd_slow_write show_bs_buffer max_iso_setting [t_app] mode : %d, change iso index to %d dynamic_brc stream_id = %d
MaxBitRate = %d
AvgBitRate = %d
MinBitRate = %d
t app test dynamic_brc [0
ri | 1: sec] [MaxBitRate] [AvgBitRate] [MinBitRate]
pb_zoom x = %d, y = %d, factor = %d Usage: t app test pb_zoom [x] [y] [factor] ZoomX should be 1 ~ n ZoomY should be 1 ~ n Usage: t app test dzoom [factorX] [factorY] [shiftX Pixel] [shiftY Pixel]
[t_app] Usage : t app test set_wb [video:0|still:1] [RGain] [GGain] [BGain]
Usage: t app test <option>
Test option list:
chg_res
chg_LCD
chg_mode
chg_app
graph [set_debug_level | set_debug_module]
save_osd
convclut
freq
extenc [on | off | set_freq | sw]
texttrack [on | off | sw]
wakeup [alarm time(sec)]
enc
video_tlapse [ 500 | 0 | 1 | 2 | 5 | 30 ]
gui_ani [start | set_dly]
beep [play | set_vol]
vf [on | off | sw]
rtsp [on | off | show]
rec [av | v | show]
ps
idr
np
sharepv [init | en | dis]
ae_meter
awb_setting
iso_setting
shutter_setting
scene_setting
crop_file [input name] [output name] [start ms] [end ms]
video_rot [rotate index]
MCTF_off [0:enable MCTF |1:disable MCTF]
sensor_flip [1:flip |0:normal]
EIS_enable [1
n |0
ff]
SS_enable [1
n |0
ff]
OSD_rotate [degree:0, 90, 180, 270]
b_shutter_setting [shutter_time_s] [ISO/100]
max_shutter_setting [shutter_idx]
single_ituner [1|0]
dual_stream [1|0]
enable_rawcap [1|0]
slow_motion [2|4|8]
app_status
enable_CFA [1|0] [width] [height]
set_EIS_range [%]
show_temp [0|1|2] (0:disable, 1:show always 2:show only when over threshold)
dbg_dsp_event [0|1]
sd_slow_write [threshold in ms]
show_bs_buffer [threshold in MB]
max_iso_setting [video:0/still:1] [ISO value]
dynamic_brc [0
t app test cache_dbg [1|0]
t app test adj_custom [0~2]
audio_effect channel [0|1]
channel_config [config]
usb_host [1|0]
set_qv [1|0] [delayms]
detail
Key list:
up
up_rel
down
down_rel
left
left_rel
right
right_rel
zoomin
zoomin_rel
zoomout
zoomout_re l
set
focus
focus_rel
shutter
shutter_rel
record
mode
menu
power
del
stop_wifi
poweroff [time]
pc [help]
up_rel down down_r
