Z60 Rear Camera issue
waikeungtk
Melbourne
I Install the z60 front and rear camera , I try to use the hardware kit to connect it work but after hide the cable and start again its announce" rear camera faulty ", dose someone know any reason? the cable no any damage..Thanks
Gday. Welcome to the forum waikeungyk.
ATM trying the Z60 Master, i too have gotten this at times, that be while installing it, after it have gone in and the wires in place i have not heard this.
Also before i got it in the car i ran it in the living room window testing memory cards, dident take much meddling with it to cough up a issue with a remote camera.
The wire harness is a bit different as i am used to connecting remote cameras directly to the front main system, guess they also do on the Z60master but with a twist.
But ever since dual systems came about and so with a remote rear camera, issues in this regard have gone up of course, and very often due to either broken wires or plugs coming loose.
Plug in rear cameras can for instance happen if you have too much wire there and so it can wiggle loose over time or by slamming rear hatch in my case, so important to use a couple of cable holders in that area.
I do have some slack on the rear wires in the front, but as i said have not had this on sort of OK Danish roads, maybe if you hit more bumpy Aussie rural roads a disconnect would happen faster.
z60m-install-webp.93923
Any plug to plug connections, after properly connecting the two, you could secure them by wrapping a little tape around the plugs so it would take more for them to wiggle apart.
My car have precious little room above the headliner in the front, so had a hard time cramming everything in there as there was already wires from other system.
From what I read, I presume the rear camera worked before you pulled in the cable and hid it. Is that correct? If so, that cable may now be faulty. If you or a friend has a digital voltmeter, you can ohm out the ends to check for continuity, high resistance, or an open on one of the wires. As I recall, on the N5 Pro, if the rear camera cable is not present, the main camera will say the rear camera is missing. If the cable is plugged into the body of the main camera, but not into the rear camera, the main camera will say the rear camera is faulty. I presume the Z60 is the same way.
You are probably better off to contact DDPAI and ask for tech support, this may be a warranty issue with the rear cable or the rear camera.
To add to this in my testing of the Z90 Master I had the same issue several times. No matter what i tried it didn't work, and even during drives it would suddenly throw up a rear camera error.
Best course of action is as Lufa said, to contact DDPAI.
