- May 1, 2013
- Dublin
- Ireland
Review of C1W-C ( Capacitor based ) Dash Camera
This is a "brother" of well known budget dash camera G1W that got popular this year as a good value for money car dvr, which is based on popular combination of Novatek NT96650 CPU and Aptina AR0330 CMOS sensor with F1.8 lens aperture.
![G1W-C (1).jpg G1W-C (1).jpg](https://dashcamtalk.com/forum/data/attachments/2/2567-c09e8adab8f3a0a986256af50b54a6d8.jpg?hash=wJ6K2rjzoK)
![G1W-C Mounted in car (1).jpg G1W-C Mounted in car (1).jpg](https://dashcamtalk.com/forum/data/attachments/2/2571-91b9e7770a3cc7106933956ff3010a9a.jpg?hash=kbnndwo8xx)
![G1W-C Mounted in car (2).jpg G1W-C Mounted in car (2).jpg](https://dashcamtalk.com/forum/data/attachments/2/2572-d12ba69029082e72e64ce5810adb0f49.jpg?hash=0SumkCkILn)
Overall G1W and G1W-C main specifications, performance and video quality recording is the same apart from G1W is uses built-in battery and G1W-C is based on Capacitor ( dual SuperCap ) which allows to save last recorded video clip and keeps time and device settings in the memory.
Till now there are only some Korean high-end dash camera manufacturers used capacitors instead of batteries, but end of 2013y showed more and more high-end dash cam manufacturers realising problems if using batteries inside dash cams, so they now going over to capacitor based dash cams. But we all know that Korean high-end dash cams are quite expensive and not all people can afford them.
G1W-C is the FIRST Chinese dash camera which is based on Capacitor. I haven't even seen yet any mid- and high price-range Chinese dash cameras based on capacitor ( 50-150 usd price range ). So for G1W-C developers being budget dash camera it is well made decision to start producing dash camera that can be affordable and at the same time with good specifications and performance.
Pros / cons of capacitor vs battery in dash camera.
Battery based dash cams has been reported having problems working in hot countries, due to battery overheating or even exploding. Many manufacturers advertise having battery in dash cam as positive thing, - you can record videos even without external power source, - yes thats true, but let's think in real life we all have mobile phones these days, so we can use them to record footage outside the car if needed. Most battery based dash camera will record around 20-30 minutes if fully charged and this is when they are new. ( latest Mobius and Innovv can record about 1h +/- ). After some period batteries lose their memory ( capacity ) and you are lucky if you can record few minutes footage. After some period of use batteries in many cases can die, so you end up in situation where your dash camera will not save last video file which is in most accidences is the most important video footage you want to keep as an evidence.
With Capacitor based dash cameras there are almost no worries with overheating issue, no exploding batteries, no risk of last file not saved. The only drawback with capacitor based dash cameras is that you can not record footage without external power.
Package content of G1W-C is standard as with most budget dash cameras.
- packaging
- dash camera
- suction mount
- miniUSB to USB2.0 lead
- miniUSB cigarette lighter charger / power adaptor
- user manual in English, Russian and Chinese lanugage
![Packaging.jpg Packaging.jpg](https://dashcamtalk.com/forum/data/attachments/2/2574-66e23056e7d48397a90d950271596daf.jpg?hash=ZuIwVufUg5)
Menu interface is the same as on G1W
![G1W-C (3).jpg G1W-C (3).jpg](https://dashcamtalk.com/forum/data/attachments/2/2569-94aa2544eb4c1c2a22ba7fca03772fdf.jpg?hash=lKolROtMHC)
![Buttons names.jpg Buttons names.jpg](https://dashcamtalk.com/forum/data/attachments/2/2566-a1d831d92eed4ccdabb0b6faddbe9d21.jpg?hash=odgx2S7tTM)
Main Features:
· FULL HD 1080P high quality resolution.
· NT96650+AR0330
· 120 degree A+ grade High Resolution Wide Angle Lens.
· Lens aperture F1.8
· Wide Dynamic technology ( firmware enhanced )
· H.264 video compression technology.
· Video recording in MOV
· Video recording bit-rate: average 12Mbps
· G-sensor function.
· Built-in microphone/speaker.
· Supports high capacity TF card up to 64Gb (Fat32 ).
· Seamless looping video.
· Support anti-shake function.
· Motion Detection.
· Support HDMI high quality video transmission.
· support auto ignition boot, turn off shut-down.
ADDED:
G1W-C works with Samsung 64Gb MicroSDXC ( MicroSD, Micro SDXC )
![G1W-C (4).jpg G1W-C (4).jpg](https://dashcamtalk.com/forum/data/attachments/2/2570-dde21ea81d36618633d9d0969102976d.jpg?hash=3eIeqB02YY)
Specifications:
- packaging
- dash camera
- suction mount
Main Features:
· NT96650+AR0330
· Motion Detection.
ADDED:
Specifications:
![Specs.jpg Specs.jpg](https://dashcamtalk.com/forum/data/attachments/2/2573-b1eadc8239c0d504c47e46b35d6a52f0.jpg?hash=sercgjnA1Q)
