- Oct 2, 2013
- United Kingdom
- Mobius
I can assure you that will most likely never be implemented. There are many more important features to implement and only very few users who edit the config file. The config file should be considered as an emergency configuration tool in case Windows or a compatible smartphone is not at hand. We should appreciate the fact that the file is available. Other systems don't have both a GUI and a file configuration possibility.I thought about this some more yesterday. I was at a client's, and used a idle XP box to try the GUItool for both the 0.53 upgrade and fiddling; vs. editing the CONFIG file.
I realized that the biggest thing that annoyed me about the date issue is saving/loading the file back & inadvertently resetting the clock to an old value.
So my idea is this:
Make the Date line written out to flash invalid enough so it will NOT be accepted & processed when loaded, just ignored.
You have to fix it to make it valid.
This could be one of many forms:
- Date time=[????/??/??-??:??:??];date time setting,format yyyy/mm/dd hh:mm:ss
- Date time=[2013*06*28-21:33:34];date time setting,format yyyy/mm/dd hh:mm:ss
- Date time=[?013/06/28-21:33:34];date time setting,format yyyy/mm/dd hh:mm:ss
and others. Assuming there's a value to have the timestamp of when the CONFIG was saved rules out the first.
But any other alteration could work.
I can well imagine the config file will be dropped if the developer runs out of code space.
