- May 1, 2013
- Dublin
- Ireland
Hi all first time posting here! Got my panorama last week and the experience has been quite good until today. I think I might have bricked the device, so I plugged in the power cable to the device when the key is in the first click position and so it powered up as usual, but then when it is still in the bootup screen I fired up the engine so the dashcam shut off and reboot and now the device only shows the bootup screen then a blank screen and I don't think it is recording at all. Any advice for me? I am guessing I can flash it with the firmware v1.12.02 as most of your guys here are loving it.
Remove SD card and try to start up in car. What does it says ?
ALso try connect using mobile phone charger at home via 5v power socket on the top, turn on. Let know what does it do then ? ( again, - without sd card inserted )
So after some more observation, the blue light next to the screen is flashing when I have the SD card in the device when powering up, but when the SD card is removed when powering on that same light goes into flashing red and the device beeps serval times.
The screen goes blank showing nothing at all right after safe driving-blackbox bootup screen, with or without the SD card installed. Also I heard that beeping sound when I drive over a pothole this morning (G-sensor), so I assume it is still recording? I will try to play the clips in the card tonight to confirm.
It sounds like you got an S.A blue LED blinks through the middle hole on my device.
OopsSo I figured out what is the problem. I plugged the GPS into the AV/out by mistake and hence nothing showed up on the screen. Case closed.
http://dashcamtalk.com/forum/threads/powerucc-panorama-s.4286/
This picture shows an LED in that location. It otherwise looks very similar. Maybe it has the II case with the S board?
But yes, a blue light in the front in many countries would be illegal because it looks like a police light. For now maybe put some black tape over it?
Oops
I'm in the same boat. I received a PII last week, and it came with a lens cap and front AND rear blue LEDs. I'll check the firmware version when I get a chance.Thanks, that would be useful.
I don't think I got a Panorama S, it's a II for sure. Here is where the blue LED is located:
How corrupted file can be played??Guys, can someone share official firmware for Ukraine (I think same is for Russia)? I still have corrupted videos on FW 1.12.02, even after I changed SD card to Toshiba.
If original software will not help, I will go to the dealer to change or repair the device.
Buy the way these corrupted videos gives error in windows media player "Windows Media Player encountered a problem while playing the file.", but if I press play again videos is playing from begin till end. Also windows disk checking see that these files are corrupted.
Very easy, if you copy some video file on usb drive and during copying pull out stick in the end of process some players can play this video but not fully.How corrupted file can be played??
It seems other pc problem.
You can try to play at machine also.
Kmplayer also can help to play
... and during copying pull out stick
Why you do this ?
This can caus file corruption.
Please try to play files directly from memory card inserted into laptop / usb card reader via VLC or Registrator Viewer.
