I'm having an installer hardwire my dash cam but they normally install audio systems not dash cams. So they will be a little unfamiliar with the dash cam install. So what's the difference in these two power adapters?
https://www.amazon.com/gp/B00VLAEPJ0
https://www.amazon.com/gp/B00JFUU87G
What voltage should I use as a cut off?
Is it best to hide the black box shaped section of the power adapter? The 2nd one has a button. So I'm not sure if it needs to be hid or not...not sure if I will need to locate it in the future. The first one has no button and may lead to less confusion by the installer but the voltage can't be changed. Will I need to change it at some point?
Thanks guys!
Thanks guys!
