G90 - very silent recording
no_hits
Brno
Czech Republic
G90 A7LA70 v1138
Hi , I have G90 with A7LA70 chip, firmware version is G90-ZX-A770-1138-S7W.
Audio in videos is very silent , i tried to change assembled microphone, but it was worse, so i returned it back. Is it firmware issueand how can i edit it in AFT ? ? Thanks for your reply
Initial versions of G90 had bad distortion so looks like they toned down the audio volume to fix distortion.
very lower sound volume, sorry for bad description, but now i'm solving ...you know
We don't know unless you tell us. 😉
I have same firmware. Volume level changes depending on which resolution you use. The very high res seems to have very low volume but the HDR setting has the highest volume.
At first I thought the sound was not working at all on high res, but it does work just very low volume.
but HDR is only 30FPS and in my case it has same volume level as other modes, so i have to conciliate with low volume level , at least to new firmware.
I have the same issue. Any new firmware solving this low sound problem?
