SawMaster
- Apr 10, 2015
- SC
- United States
- Numerous and ever-changing
I never had any problems with my G1W-H's latchless T-bracket mount. If fitted so tightly that I doubt anything could make it slide out of the slot.
The ones I got don't inspire confidence with the mount fit; they're looser than my Spytec G1Wc latched type mount was. I made a mount for the rear cam and will shim the side cam mount soon. It is still a shorter and more rigid mount than the ball/socket type.
@Pepnyc- That was after I got it towed home; it was an accidental roasting.
@ThePro- The G1W, A118, ans B40 cams are generics- several manufacturers with several firmware variations. Unless bought from a recommended or known seller you can't be sure which you're going to get and they can vary.
