I installed the firmware the day before yesterday and tried it a bit.
At first reboot the cam started in Russian so it was a bit searching and trying where the language menu was
Then I recompiled the firmware with my language strings I made on the 150323 firmware (I added the Dutch language), I also changed the splash screens and added a silent boot and shutdown chimes. I just copied these from the last firmware and everything looks fine so far. I don't know if there were any changes in this new firmware in this area, I just gambled on trial and error.
I'm not impressed about the video quality but maybe it's because I was used to the quality of Nigel's work on the 150323 firmware.
I could not test the card switching yet if this is improved, I only filled about 30GB of the 64GB some some miles to go before I can report on this.
@Nigel
Could you do your excellent work also on this firmware to improve the quality as you did on the 150323 firmware? Please?
I'm willing to do it myself if I knew which values I have to change
Nigel's table of the 150323-DCT Firmware
Current firmware 160507
I guess at least bitrate #3-5, #12-14, #45-50, so all rows which contains the range 1.0?
