What is your white ballance setting? If you use auto, try to switch it to fixed one (daylight), also different metering mode can help (average instead of center)I will also buy some filters, because the color in the sky changes too much during the auto exposure.
i know it gets plenty hot in afghanistan, but i live in texas, where it also gets quite hot. right now at 9:40am, it's already 30c with a heat index (temperature + humidity and wind = "feels like") of 37c. forecast high is 34c, heat index of 41c. today is a COOL day because there's rain in the forecast this afternoon. for the rest of the week, the forecast is highs of 36-38c, with LOWS around 24-26c.What I have heard black clothing its the best way for heat dissipation - thats why it is used by many native peoples around the world in hot environment. I would assume that the effect is the same with casing where transparent or white case will lead to poorer heat emission/dissipation ratio. Casing material and surface structure will probably contribute the most to the equation, cf. radiators in non-vacuum environment.
well they're easy to take apart so you could paint it yourself if you were so inclined... the git1 comes completely clear from its case, but the git2 wifi antenna is soldered rather than socketed (not sure why) so you'd have to mask off the internals, but it would still be pretty easy to paint. and since the ring around teh camera comes off separately, you could get fancy and paint it a different color if you wanted. i'd keep the lens ring black though just so it doesn't reflect any colored light into the edges of the lens.Let's build a white cam Gitup! Come on! π
I know it's counterintuitive but there's a lot info about this around the Internetπ
See e.g. http://io9.gizmodo.com/5903956/the-physics-that-explain-why-you-should-wear-black-this-summer
You would be better off fitting a heat shield on the front to prevent sunlight directly reaching the camera. Given that sunlight isn't directly reaching the camera, a black camera is always going to be cooler than a white one.
Regarding the color, we have prepared the 3 different color version, but due to no enough sensor in stock now, so haven't started the production.The white camera was just a little joke. π
But if someone is interested, there is a prodcut called Plastidip that you can peel if you change your mind later.
It is Git2, of course the color is different compared to SJCAM.Are you referring to the Git3?
If so, please keep closer to GoPro colors, instead of SJCAM. π
Is this going to be the special 3 colour UK version πRegarding the color, we have prepared the 3 different color version, but due to no enough sensor in stock now, so haven't started the production.
I think Gitup did understand, unless I also didn't understand you?It seems that you didn't understand what i said.
Like this:
Yes, the color is not similar as SJCAM use.I was saying, "if you are going to have 3 colors", do not follow the color scheme the sjcam uses (blue, red, yellow, etc.) it would be better to use gopro-like colors; black of course (Git2 official color), silver and white (now, if GitUp came up with better choices, better yet). Other colours like sjcam uses make cameras look like too much plastic/toys. That was my point, to avoid "plastic" colors.
Then, the dimensions, shape, button placement and name structure on the Git2, is an original idea? π΅
