Joel Irwin
- Dec 30, 2015
Came back into the garage as I normally did and turn off the car. Instead of the normal shutdown sound it beeped three times and I shut it off manually. Waited a bit and turned the car back on to see if unit worked and it turned on fine with the expected sound. Then shut it off again and it shut off fine.
In house, looked at card. I am using a spare 8 GB SD card which was working fine until today (while I wait for the Samsung 64 GB I ordered). Looked like the card was almost full but only one MOV file (the one I got from that last turn on). Should not have turned it on since that one file clobbered the final file I could have used before the 3 beeps (you learn....)
I was able to recover all the files with Recuva (except for the last one) to another location and I used the unit to reformat the card.
Not sure what caused the 3 beeps and the messing up of the files in the first place but of course, I/we can blame it on the sd card. I'll see if it happens again though I should be switching to Samsung in the next 3 or so days.
