Jagmanmick
- Jul 15, 2014
- Scotland
- United Kingdom
- A119 PRO, 412GW, Mini 0801
Just noticed the new firmware update for the 412GW. Anyone know what the changes are?
Any chance of allowing a cut/paste instead of just the copy/paste in mass storage mode ? (like my 402)
How did you revert back to R9.5? As I’ve done the latest update and I’m not a big fan of the high & low saved files on the laptop. I would rather have a high file and that’s it done with much easier imo.Had a look and then reverted to R9.5. Option to remove Nextbase has been replaced by the option to remove the model number. Lettering has been added to the top right of protected files telling you when it was protected.
Sorry but the top 2/3rds of the display should be totally clear. Put any additional info in the bottom 1/3rd which is normally the top of the dashboard or bonnet. The existing info can be smaller to accommodate this.
I was also getting 2 files recorded with the same time and date, one which said Lo at the end of the file name and the other that said Hi at the end of the file name. This is new.
Also on viewing a protected video in Nextbase Replay 3 the red font protected file info that has been added in the top right was momentarily changing to a yellow font model number for a couple of frames. What is all that about!
Don't know what the difference is in the Parking mode, option is still hidden away. The most used options should be on the first menu page. Very disappointed with this update so reverted back to R9.5
Just a normal firmware change using the R9.5 firmware which I have a copy of.How did you revert back to R9.5? As I’ve done the latest update and I’m not a big fan of the high & low saved files on the laptop. I would rather have a high file and that’s it done with much easier imo.
