country_hick
- Dec 10, 2014
I could not find a one piece 10 to 15 foot long USB power cable with an up or down angled 5 or 10 pin mini USB end at a reasonable (or unreasonable) price.
It finally occurred to me that 2 usb cables could be used to make one reasonably priced cable for what is needed.
The connection where the 2 cables plug together might be unwieldy in some installations.
I found these cables on walmart.com. I looked online to find link depot claims to use high gauge copper power wires (I saw one description say somewhere around 21 to 24 gauge). The data wires are thinner copper coated steel. http://www.link-depot.com/ These cables come from walmart so they should meet minimum quality standards.
If having an angled mini end does not matter to you either of these next 2 cables should offer reasonably priced solution for a long power cable without waiting for delivery from China.
Link Depot USB 2.0 Type A to Mini B Cable, 15' $3.57
https://www.walmart.com/ip/Link-Depot-USB-2-0-Type-A-to-Mini-B-Cable-15/15779597
Link Depot 10' USB 2.0 Type A to Mini B Cable $2.45
https://www.walmart.com/ip/Link-Depot-10-USB-2-0-Type-A-to-Mini-B-Cable/15779590
Ebay has a Mini 5Pin Male to USB Mini 5Pin Female 90° hard plastic Angle Adapter for $1.39. Plugged into either cable above this could provide the angle desired.
Is the right angle correct for this application?
https://www.ebay.com/itm/252318654735
You could plug a cable that is angled, up, down, or sideways into a usb extension cable and apply some electrical tape on the joint to guarantee the 2 cables would not separate to obtain your needed length cable. 2 USB ends taped together might be annoying in an installation and might make it difficult to install depending on how your car is made.
6' usb extension cable (can plug into itself) type-a-female to type-a-male, black $1.55
https://www.walmart.com/ip/Onn-by-W...e-type-a-female-to-type-a-male-black/48031949
C2G 3m USB Extension Cable (can plug into itself)- USB 2.0 A to A 10ft $6.58
https://www.walmart.com/ip/C2G-3m-U...PCs-and-Laptops-10ft-USB-cable-10-ft/15172656
These StarTech cables may or may not be an option to consider. Wire Gauge: 28 AWG (copper???) Cable Jacket Type: PVC (per an ebay description)
StarTech Mini USB Cable A to Right Angle Mini B, 6', Black $4.21
https://www.walmart.com/ip/StarTech-Mini-USB-Cable-A-to-Right-Angle-Mini-B-6-Black/21310275
StarTech 2m USB A to Down-Angled miniUSB B Cable $5.65
https://www.walmart.com/ip/StarTech-2m-USB-A-to-Down-Angled-miniUSB-B-Cable/35461706
StarTech 1m USB A to Up-Angled miniUSB B Cable $4.65
https://www.walmart.com/ip/StarTech-1m-USB-A-to-Up-Angled-miniUSB-B-Cable/35461708
Walmart also lists 25' and longer USB extension cables with a built in repeater for house use.
Moving on to ebay...
We can find an up or down angle mini usb cables to plug into a full size type A end on ebay starting at $1.26 that are about 1 foot long but the quality may or may not be lacking.
https://www.ebay.com/itm/263833591516https://www.ebay.com/itm/271765579731
Mini USB to Mini USB extension cable with an angled end
The listings do not say if the wires are copper or foil covered cotton. This option may save a few $$$ or waste them.
A left, right, up, or down angle adapter 1 foot mini usb extension cable is available here for US $1.19.
https://www.ebay.com/itm/252631161785 I bought one of these. The "up" version was correct for an upside down mobius maxi. It is just shy of 11" long at about 276mm going from one end of the plugin to the other end of the other plug in. It is about 10 1/4" long measuring from the plugged in end to the connector which should have the longer usb cord plugged into it. That extension style end has a small hole built in to allow a small zip tie or string to hold the 2 cables together which is a nice design feature.
These angle adapters look identical to the cables directly above for 40 cents more. US $1.59.
https://www.ebay.com/itm/201708628963
https://www.ebay.com/itm/263307791006
If you do not mind a full size USB plug hard plastic adapter ebay has them.
I would be concerned about the extra weight and road vibrations causing a leverage problem creating long term stress damage to the usb port of the camera.
90 Degree down angle USB Type A Female to Mini B 5 Pin Male Converter Adaptor $1.39
https://www.ebay.com/itm/252186501183
3 Pack Right/Up/Down Angle 90° USB Type A Female to Mini B 5pin Male Adaptor $3.47
https://www.ebay.com/itm/263291637066
If you use a full size adapter for a type A USB plug in you will need to use a cable like this.
C&E USB 2.0 Type A Male to Type A Male Cable, Black, 10 Feet $5.22
https://www.walmart.com/ip/C-E-USB-2-0-Type-A-Male-to-Type-A-Male-Cable-Black-10-Feet/216648060
