512gw
Sirathol
Brand new 512gw and I have a problem. Although by default the camera records two versions of every clip - one hi and one low res- there is apparently a facility to turn off the low res copy.
If I select "Off", which I presume means I should only get the high res version, I still get two copies of everything and they are all numbered sequentially and all labelled "Hi"...which is incredibly confusing.
If I select "ON" I also get two versions - one hi, one lo but they are not numbered or labelled at all. I am sure this can't be right and would welcome some advice...I am a first-time dash-cammer so be gentle.
Also, while asking for advice, I contacted Nextbase about the permanent log display and they sent me a firmware update which they said would remove it. However, they didn't tell me how to install it and my attempts have failed...can anyone tell me (in simple terms please), how to do this.
Put the BIN file on an SD card and put it into your 512GW.
Make sure you're camera is connected to a power source and not running off battery.
The firmware update should then run.
Nextbase are right, the firmware update will resolve that issue and stop it recording 2 separate files.
Regarding the firmware they sent to you to remove the logo, be advised that this particular firmware is a 'one-off' solution to removing the logo. If you want to have the logo removed permanently, they you CANNOT update to a newer firmware at a later date. Well, you can update to a newer firmware, but you WILL then have the logo back again.
This was discussed in great detail in the following thread:
https://dashcamtalk.com/forum/threads/512gw-recording-mode.32049/
Thank you for responding and for that information,
but the firmware was to remove the logo...not stop dual recording. There is an On/Off switch for stopping dual recording but it is not working and files are being incorrectly labeled, that was the basis of my original enquiry.
Hi Sirathol and welcome.
One problem you may find is that with the camera in your hand and powered by the car or domestic phone charger its possible to operate the buttons very quickly, such activity can throw the whole camera out of sync.
It is far better to work slowly and methodically through the menus, that way it will keep pace with your actions and you wont need to go back to Start (eg; do a reset).
The 512GW software isn't the sharpest tool in the box as you will discover if you read through the various posts on here.
Tip; ensure you only use Endurance, Industrial or MLC cards from a reliable supplier as it will cut out the problems involved with counterfiet and unsuitable cards.
(I only buy from Scan.co.uk.)
Thank you Mike, that is very much appreciated. I have reset the unit and entered my preferences again...slowly...and will see what happens now.
Do you know if there is a mount available that will set the lens closer to the windscreen as - even with the polariser - my windscreen reflects very badly and moving closer to the glass would help reduce that.
Presumably you have rotated the polariser for minimum reflections? The polariser nearly totally eliminates windscreen reflections altogether on my wife's 312 and on my BV 750.
Yes, I've done the white paper routine and set the polariser to best effect but our windscreen is appalling for reflections...it's a Mazda 3...with cream side bars down the edges of the windscreen and even the polariser cannot eliminate their reflections in the window. I just felt that getting closer to the glass would remove them from the viewing angle of the lens and reduce other reflections. Not a major concern but I just thought I would ask while I'm here.
With my 512G I could remove all reflections by turning the filter, with the 512GW it made no difference whichever way I turned the fliter.
The interesting thing was that neither camera showed a reflection when replayed on the computer (Mac Pro) ???
I have recently installed the 512G in a VW Up and removing the refelctions was again a doddle, yet to check-out the results on Replay.
I drive a Golf, not that it should make any difference.
I am being a bit picky here because I am using the camera for a use it was not intended for. I live in the New Forest and I want to record the animal action that takes place in front of the car as we drive through on a daily basis. The results I am getting are perfectly good enough for accident recording and the like, but I am striving to get the best quality I can for the wildlife.
Thanks for your input...you have been a big help.
Your not being picky at all.
I also live near the Forest and drive through/across it regularly, I am also interested in the wildlife that crosses the road, insists on nibbling the grass beside the roads and regretfully dies on the roads.
Im also interested in those idiots who break the speed limits across the open Forest and by doing so endanger the lives of 'our' animals.
You are not alone.
What an extraordinary world we live in...of all the people on this site, I get into conversation with a guy who lives just up the road. Amazing!
We live in Christchurch and visit the forest every day to walk, photograph and video all the best that the forest has to offer, we belong to several Facebook groups where we post pictures and videos, and we make videos to share with friends and relatives in different parts of the world
...hence my need of the dashcam.
Sounds like we have things in common.
