asurabro
Hello to all,
I'm having an issue with my A119 mini on parking mode. Whenever the temperature outside is about 30~40c my dashcam would shutdown. However, in winter it would never shutdown like this way. I contacted viofo they told me it's a misconfiguration issue but didn't provide me with a real solution. The solution provided was "change where you park your car" which isn't an option for where I work.
I use Auto event detection, 1440p 30fps, max bitrate recording, wifi off, audio recording off, HDR off and GPS module turned off. I'm using a Sandisk extreme 512gb also tested with viofo 64gb sd card the issue still persist. I have also tried low bitrate recording, issue still present.
Also I'm using the latest firmware V1.120230420 from viofo support page for the A119 Mini.
Thanks.
Thanks.
