Are you sure that it isn't just the memory card coming to end of it's life?My original A119 is coming to the end of the it's life, can I reuse the GPS mount if I purchased the A119 v3?
You could try copying Kremmen and plug it into a wall charger for 24 hours, the RTC charges very slowly so that may bring it back if you've only been making very short journeys. Of course a V3 is a nice upgrade, so that may be preferable anyway.The capacitor doesn't seem to be holding much charge anymore so when the car's not in much use, which is quite a bit at the moment, the dashcam keeps resetting itself including the date/time, which in turn is causing a bit of a problem because no files are being saved due to all of the existing files on the SD card have a later date and therefore can't be overwritten.
