What card are you using?Hi All,
Just picked up the A119 Pro and after installing a 128 Gig Class 10 card the camera takes a picture and freezes with a red x in the middle of the screen. Any help will be greatly appreciated.
I would suggest trying the firmware update and use the same card. If you change two things at once and your problem is solved, you don't know which one fixed the problem.I'm using a Lexar 128 Gb class 10. It simply takes a picture and freezes with the red x. So, not sure if it's a defective unit. I'm going to start with the firmware update with a smaller capacity card and hope it works.
Lexar cards have been an issue as of late too. Many users have experienced issues with the later model Lexar cards. For testing your issue I would definitely try a small GB card.I'm using a Lexar 128 Gb class 10. It simply takes a picture and freezes with the red x. So, not sure if it's a defective unit. I'm going to start with the firmware update with a smaller capacity card and hope it works.
You want to make sure you format in the cameras, even after formatting on the computer. If you format on the computer first, be sure to use Viofo's GUI Format tool (found HERE) or SD Memory Card Formatter (HERE). I would not use the Windows default format program.I have already formatted the card in the computer.
