Yep, that's what I was thinking... Looks like something is wrong with the card...once the card fills up it deletes the oldest file to make room for the next file, FIFO (first in, first out) so that you always have the most recent several hours of footage at any given time
Make sure your date/time is set correctly, else when the card is full, the camera may delete the newer files if they are time-tagged with an older date. This can happen if the date/time is not maintained or if the camera for some reason reverts to the default date for the firmware being used. Using GPS should keep the date/time up to date automatically.Is that normal? Any methods to change this...
That's true in some cases, but I think the camera determines the sequence of the video files by the id which came after the date in the filename.Make sure your date/time is set correctly, else when the card is full, the camera may delete the newer files if they are time-tagged with an older date. This can happen if the date/time is not maintained or if the camera for some reason reverts to the default date for the firmware being used. Using GPS should keep the date/time up to date automatically.
