Viofo recommends one at each end if you are having issues, both ends are 5mm diameter cable.
Perhaps they should acknowledge another of the Viofo A129 Duo's serious deficiencies, and include those ferrite chokes in every box.
There are many accepted techniques to reduce EMI during design phase ranging from proper placement of components on a circuit board to selection of higher quality components with tighter tolerances. In their design lab, they should be testing for EMI early on, and not pushing it off to customers to later discover and correct on an individual basis.And i am sure all of the decent brands do what they can in this regard too, but of course they could turn to ALU billet camera housings milled out on a 5 axis mill, and cables that are much better / much more expensive.
That's valid to a degree, but it's much easier to produce a product that does not spew EMI than it is to produce one that is resistant to EMI. Cars are not military helicopters, and shielding them from all forms of potential EMI would likely add thousands of dollars/euro to their cost. One could argue that we can make all cars bulletproof too, but then they would weigh twice as much and cost twice as much too.Maybe we should also focus on the car makers, i am sure they could do better too.
We probably don't really need all this electronic crap built into our cars, but it keeps getting pushed onto us by manufacturers and governments. I choose a use a dashcam to counter the stupid and negligent actions of other human beings who don't drive responsibly, and then tend to lie about what really happened in an attempt to deflect personal responsibility. But that dashcam should not create potential situations which would put me at increased risk. We should not have to worry if that same electromagnetic interference might cause our airbags not to deploy properly.Maybe one day if i am unlucky the remote open / close door thingy in my car key will not work, but even if i have used that for many many years i am sure i can deal with going back to using the key in the door approach.
I would rather do that then having to tear my car apart problem solving a issue.
But they are not needed in most vehicles, which suggests that the problem is mainly caused elsewhere. Maybe there is another device in the car causing far more RFI and adding a small amount from the camera pushes it over the limit. Or maybe the tire pressure sensor receiver is not working correctly and just a small amount of extra RFI means that it can't receive any more.Perhaps they should acknowledge another of the Viofo A129 Duo's serious deficiencies, and include those ferrite chokes in every box.
I would also assume the devises adhere to the different levels of EMI radiation allowed in the different countries, otherwise they could not be sold there i assume.
Of course not factoring in private imports and customs as incompetent as Danish customs often are.
And some times the sellers, like when ebay turned my first Lukas camera around as such things was not allowed to send to Denmark.
I mailed ebay and told them yes we Danes are a Fked up little country, but we are not yet N Korea Fked up, and import of any form of video recorder are allowed.
And then proceeded to get the camera from the sellers B&M store in NYC, so no cut for ebay on that deal.
That may be a bad assumption.
Here in the US, there are strict federal rules for limiting EMI from electronic devices, but lax enforcement. However, if causality is ever proven between stray emissions from dashcams contributing to the failure of automotive safety systems, and especially cases resulting in deaths or critical injuries, you can bet that will wake the beast and close off the market to those manufacturers that don't comply with existing regulations. Again, the most responsible manufacturer(s) should benefit in the long term.
If the tire pressure sensors are that important to the car then maybe they should have receivers at each wheel instead of a single one in the cabin that has a lot of metal blocking signals thus making it susceptible to interference, the wheel rotation sensors will certainly have receivers at each wheel since they are very important to safety. My car seems to work perfectly well without tire pressure sensors, I'm not convinced a lack of signal should have any significant effect on other safety features, and it should be easy enough to use wheel speed as a backup, if one tire goes flat then that wheel will turn faster than the others due to reduced circumference, and the wheel rotation sensors will see that.
Like Kamkar said, if the camera really was producing unacceptable levels of RFI then lots of owners would be having trouble with tire pressure sensors, but the numbers actually seem to be very small, far more common is DAB radio interference, but everyone should have that when they drive into very low DAB signal areas.
a product can be within the allowed limits of EMI and pass the tests, that doesn't mean they won't interfere with some other devices though, can and does happenIt serves no one to make false promises that the EMI is nothing to be concerned about.
FCC ID 2AMBW-A129 Car Dash Camera by Shenzhen Viofo Technology Co., Ltd
FCC ID application submitted by Shenzhen Viofo Technology Co., Ltd for Car Dash Camera for FCC ID 2AMBW-A129. Approved Frequencies, User Manuals, Photos, and Wireless Reports.fccid.io
even if they proved that was the problem, if it's within the limits of the day then it's within the limits, that doesn't mean that it shouldn't or couldn't be improved, there's no product out there that doesn't have room for improvement, they could all be better
but lax enforcement
The testing was not done by Viofo, clearly the radiated emissions measurement test was done by "Shenzhen LCS Compliance Testing Laboratory Ltd." :That report essentially says that Viofo self-certified the camera to be complaint. The frequencies listed in the report are for wifi and bluetooth.
Unfortunately the FCC does not test products for compliance to the stated certifications; they accept the manufacturer's word. Hence my comment of lax enforcement earlier.
By the way, if you read about the Boeing 737-MAX airplane example I mentioned above, you will find details that Boeing essentially self-certified the airplane control systems to the FAA (Federal Aviation Administration), in what I would imagine a similar, if not much larger stack of paperwork that Viofo was required to submit to the FCC.
If you're worried about a dashcam causing EMI then the solution is don't have a dashcam.
Quite simple really.
If your car becomes dangerous to you because it can't safely cope with a bit of EMI then it is also danger to me and I want your car off the road!And as harsh as this statement might sound, I don't really care if your dashcam ends up harming you or your family. But I do care about me and mine.
