punkstoner
I have an A129 Pro Duo, with V2.2 firmware installed.
The camera goes into parking mode when I switch off the ignition (correctly)
The camera will correctly come out of parking mode when I switch on the ignition.
Parking mode is set to Low Bitrate, however, the issue also occurs when using time-lapse recording.
I have installed V2.2 firmware, and reset the device using the menu, as the reset button has no effect whatsoever (not sure if broken)
Full settings are :
resolution : 2560x1440 30fps
bitrate : high
Loop : 3 mins
WDR : off
Exposure : 0.0
Parking g-sensor : high
Parking motion : low
time lapse : off
Motion detection : off
GPS : on
G-sensor : medium
Record Audio : on
Boot delay : off (fault occurs with 5 sec delay on also)
Is it the camera, my car or the hardwire kit? Any Ideas?
Many thanks,
- The camera will stay then stay in parking mode, sometimes for half an hour or so, and sometimes for 2 or 3 hours.
- The camera will then come out of parking mode and into driving mode for a while before re-entering parking mode. This behavior repeats.
- The rear camera is connected and this behavior occurs both when connected to the GPS mount, and not connected to the GPS mount so I have ruled this out as a cause.
- I've ruled out an issue with the rear camera because the behavior occurs when the rear camera is not connected.
Full settings are :
bitrate : high
Loop : 3 mins
WDR : off
Exposure : 0.0
time lapse : off
GPS : on
G-sensor : medium
Record Audio : on
Many thanks,
