No, that is not normal, first impression was that it is very out of focus, but focus is OK in places so I suspect the issue is dirt on the lens, either fingerprints or maybe the lens protection has not been removed...I have noticed that the rear dash cam appears to be blurry and/or out of focus. I compared against the Aukey DR02 it replaced and the Aukey DR02 looks much sharper. Is this normal? I feel like it shouldn't be normal
View attachment 48027View attachment 48030View attachment 48031View attachment 48032
I thought the same about mine. I haven't had my camera long or tested fully and I don't have anything to compare it to. I figured maybe the rear window was a bit dirty. I will grab some footage and have better look.
the lens is not adjusted, there is no focus in the center of the frame., and it looks better, but still not as sharp as the front camera or Aukey DR02.
That's not going to help.Move the handle so that the camera cannot see the window heating wire.
There is no problem on the glass; the problem is inaccurate focusing at the factory. This problem occurs, there should be an output control for the exact focus of the lens.I'm suspecting the remaining problem is due to something on the glass. Do you have some sort of tint on there that could be causing the issue?
Your time is 19-34, the sun at sunset.Here's an example of my rear camera. It's not great.
The camera still seems in focus to me, the poor quality seems unusual. I'm suspecting the remaining problem is due to something on the glass. Do you have some sort of tint on there that could be causing the issue?
Easy way to check is to record a little footage with the camera removed from the glass and looking through nothing but air, ideally looking into the distance but just down at the floor will do as long as it is over a meter away so that it should be in focus.
You can fix it yourself if you have the skills of disassembling and focusing the lens.Is the only way to fix the problem to get it replaced?
Try recording some video without the glass in the way, just to prove where the problem lies. If the problem is proven to be with the camera then it doesn't matter if it is a focus problem or not, it should be doing better than that and a replacement would seem reasonable.My car only has the factory tint. The glass says transparency 70% minimum. I attached some more pictures. You can see the front is very clear/sharp while the rear is soft/blurry. I took out my old Aukey DR02 and got a few more comparison shots
Ahh, didn't look at the last few, seems to have got worse, maybe something is loose?Here he has taken some pictures outside the car.
R | Viofo A129 Duo not recording if rear camera is connected | A129 / 129 Duo | 1 | |
A129 Rear Camera Or Cable Fault? | A129 / 129 Duo | 14 | ||
A129 Duo Rear Camera Issues | A129 / 129 Duo | 9 | ||
F | A129 Duo - Can you mount the rear camera on the windshield?? | A129 / 129 Duo | 14 | |
M | A129 duo rear camera mount replacement | A129 / 129 Duo | 2 |
