DashCamDelight
That was the 8th channel which I was worried about 😵
Pretty sure that "8th channel" camera is disposable after going where few cameras dare to go outside of a doctor's office!
That's my setup and plan too, though I'm considering wide angle 4K in place of telephoto for the rear.For the last five years I've had 5 cams in my vehicle.
Front + front telephoto + rear + left side + right side
Basically 360º plus
Considering adding a rear tele.
So, six channels sounds just about right.
Same camera & lens that Dashmellow linked to earlier, for my front camera:Did you modify a dash camera or what camera do you use with a telelphoto lens?
Personally, I could do without the interior camera but I would want a secondary telephoto camera facing the front. 🙂
I never drive without one!
I agree that mostly of these are geared towards commercial fleets. Here's one I found that appears to be a legitimate Dashcam vs CCTV and supports 4 additional cameras (5 Channels Total). Not sure the resolution as the literature is confusing. Don't know what they're saying by Main Stream and Sub-Stream.
- Video
- Main Stream
CH1:1080P/720P
CH2~CH5:720P- Sub-Stream
CH1:720P/480P
CH2~CH5:480P
The issue here is that either resolution (720p - Old High Def or 480 - DVD Standard) isn't all that great in 2022. And then how well would this handle in enclosed vehicle. My guess is lower resolutions may be due to limitations on the Front Camera processing 4 additional Streams at once and also to prevent front unit from overheating.
So running a 3 Channel and 2 Channel system will yield far better quality without the pitfalls. I.E. 2K Front + 1080P and 1080p (3 Channel) and 4k and 1080p or 2k and 1080p on a 2 Channel
As I believe you know, 😉 Hikvison dash cams, including the model you mention here got a lot of attention when they were introduced to the forum a while back. The AE-DI5042-G4 model you are referring to is an expensive commercial grade fleet management dash cam with Wi-Fi/GPS and 4G LTE, face detection, driver behavior analysis, advanced driving dssistance etc. Although it is indeed a "dash cam", it is designed and functions much like many of the CCTV network cameras of the type Hikvision is well known for.
A sub stream is used in network surveillance systems for viewing DVR video over a LAN or WAN when the resolution or frame rate of the recorded video is too high for the available bandwidth. So, where Channel 1 is 1080P/720P and Channels 2-5 are 720P, this gets recorded directly to a memory card on the camera and the sub stream consists of the same video streams at lower resolution sent over the network for remote viewing.
So, although the AE-DI5042 concept is similar to what @mentadent is postulating in that it has multiple channels it is in a different product category than the consumer style dash cams of the type Viofo is known for.
The mobius cameras have often been amended by hobbyists to suit a variety of uses, including RC aerial video, airsoft rifle cam, dashcam, surveillance etc. They are easy to open up, and the M12 lenses are easier to replace than with almost any other small camera.I missed that, sorry. So does this camera (Mobius) let you change lenses out? Are these lenses sold by Mobius or a hobbyist DIY project?
