A329S boot time
Have a Forester 2025 that I will be checking for parasitic battery draw. As the battery voltage tends to be low. These new cars use a lot of electric and since I bought a gasoline car would rather not plug it in every night.
Now have no parking mode and when the car is off the Dash Cam and HK-6 unit draws no power. While I only used Low Power Impact mode about 3 hrs. a week and geo-fencing at home I still had problems with low battery voltage. Enough that parking mode was shutting off because of low voltage. So until a proper fix is determined have done the following.
I rewired the Dash Cam Power Supply. I intentionally wanted to change the plus or always on wire to be connected to an accessory on only so the camera would not use parking mode. Also that would remove any drain from the battery caused by dash cam when the car is not running; it would have no power at all. To do this I removed the add a fuse wire from location 12 at the fuse panel which was always on and was a empty slot not being used. And in position 17 (right under 12) with a 7.5 fuse is a accessory fuse slot. I pulled the 7.5 amp fuse and installed it in bottom of add a fuse wire and plugged in the add a fuse wire. Only takes about 10 mins to change over.
So is it possible that the real "long startup" issue I have been seeing here is that a momentary dip in voltage while cranking the car triggering a cutoff by the HK4 box, then a complete reset of the A329S, resulting in the system missing arguably one of the most key moments in potential liability protection by video evidence - just starting a drive?
If you are aware of such a problem, why not start moving one minute after starting the engine?
Asked succinctly, does an HK4 instantaneously cut off the power when the voltage momentarily dips during cranking?
Are you certain that, while the starter is cranking, a momentary voltage drop occurs at the HK4 contacts, rather than a complete power cutoff?
As far as I know, the HK4 switches off 30 seconds after the voltage drops below the threshold set on the unit.
It also cuts off power instantly if the power supply to the HK4 itself is interrupted.
That will not remove the power that the HK-6 uses.
I wanted all power removed for possible warranty work. Get it ?
That’s understandable, but the power consumption of the HK6 itself is so low
that going through all the trouble of rewiring it wasn't really worth the effort. 😉
There is an issue. Also, there was an issue with the satellite module on the back of the radio (in the dash) causing parasitic drain. As I recall, one way to test was to remove the fuse for the radio/satellite in the engine compartment. Might have been another fuse, not positive. Check the Subaru Outback and Forrester forums.
I do not think it showed that much trouble and was not a complete rewire.
I do not think you are thinking about what really might be a problem. A one year old car and battery that is beginning to read 11.9 volts means a problem that needs to be addressed. The car is completely stock. Except for the dash cam. And for it to have a battery issue at that age and under warranty means I need to eliminate even the 10ma HK-6 that is being used 24-7. As I am writing this I know you did not get it the first time. It was a 10 min. fix to get 0 amps from the dash cam and HK-6. I posted it to show how easy it is to get rid of all power drain. Sorry you just have a hard time understanding.
And that is what I am preparing for !!
I have an 2013 Outback, so I have not been plagued with these later issues. The Satellite module and Eyesight / Auto Start-Stop have caused a number of issues for people.
The wiring and dashcam should not be an issue on the older Subarus like mine, on yours....I would pull it all out before I took it into the dealership. There is almost always a vacant fuse place to pick up power in a Subaru; however, these new ones have so much stuff on them that it is difficult at times. If you have the remote start FOB or keyless start, that is another one that can be problematic.
Thanks for the commonsense thought... I am aware, and I'm not impatient - but my wife steadfastly refuses to be bothered to wait on tech.
And I don't actually know for sure how things are working. That's what I'm here to find out more about. It's entirely possible the car IS momentarily shutting off power to the always-on circuits - but that's not my first suspicion as the dashcam is the only thing with any kind of issue right after starting up, and the car cranks as quickly and easily as anything I've driven. She says it never sounds burdened.
My wife's allergy to tech quirks isn't completely unfounded, given what others are reporting with dead batteries. Our Nissan's AGM battery lasts and lasts; the car is sometimes off for weeks without any ill effects on startup. We thankfully have not had any low-battery issues. This is why I'm flabbergasted at why the dashcam is apparently having to go through cold startups.
I started asking about this because Chuck McCoy noted: This whole issue of Bootup time does NOT effect users who have the unit hardwired (HK6), and using one of the 5 parking modes.
Next thing I'm trying is to reduce the time to the switchover to low power parking mode from 12 hours to 3 hours to see if I can sense any difference in behavior.
This entire bootup time issue does NOT affect users who have the unit hardwired (HK6) and are using one of the 5 parking modes if:
The dash cam does not turn off when the voltage drops below the set value or when the parking time set in the dash cam menu is reached.
If the dash cam turns off for some reason, it will have a cold start when turned on.
NoelC
Have you actually checked the battery voltage with a muti meter ?? And preferably after it has set a spell.
I checked it with a graphing meter at the time I installed the dashcam and found nothing to worry about. No evidence of loss of voltage at the always-on input. What I really need is another full-time battery monitor, ideally tied to the always on circuit that powers the dashcam, to give me a graph. I bought one for our other car, and having an ongoing graphic readout of battery voltage is very nice, with just a small 1.5ma parasitic drain.
Trouble is, the dashcam delayed startup problem just hasn't occurred for me, and - given pushbutton start - I can't think of any way my wife could be doing anything particularly wrong in starting the vehicle. I've watched her. I'll try to get more info once the car's been off for some days.
