A329T 3CH power draw tests. SSDs
speedingcheetah
Twin Cities, MN
VIOFO A329T 3CH (F+T+R) + Sandisk Extreme 1TB external SSD
On the suggestion of @Chuck McCoy in this post on my thread discussing the possible file corruption issues i am having when i go to remux/append all the cams video files into one single file, to check for Power Starvation issues using a USB C power meter.
Here is video of various tests i have done.
NOTE: These are not meant to be 100% perfect / scientifically accurate or comprehensive tests.
It is meant as a casual testing to see if i have some sort of obvious Power Starvation issue with my current setup.
( a few videos seems to have been cropped just a little, or i just quite did not have the meter in full frame near the end of the video...sorry about that.)
In camera:
Power Input:
A329T 3CH -Cam power input - Internal Micro SD VIOFO 512GB
A329T 3CH - Cam power input - Sandisk Extreme SSD 1TB
A329T 3CH - Cam power input - Samsung T3 SSD 1TB
A329T 3CH - Cam power input - Samsung FIT PLus flash drive 256GB
A329T 3CH - Cam power input - Remote Power Off - Sandisk Extreme 1TB SSD connected
_________________
SSD Power usage:
A329T 3CH - Sandisk SSD power up record hard power off
A329T 3CH - Samsung T3 SSD power up record hard power off
A329T 3CH - Samsung FIT Plus flash drive power up record hard power off
PC Power usage USB 2.0:
Mount / unmount:
PC USB 2.0 Power use - Sandisk ssd mount unmount
PC USB 2.0 Power use - Samsung T3 SSD mount unmount
PC USB 2.0 Power use - Samsung FIT Plus flash drive mount unmount
Write / Read:
PC USB 2.0 Power use - Sandisk ssd write read
PC USB 2.0 Power use - Samsung T3 write read
PC USB 2.0 Power use - Samsung FIT Plus flash drive write read
