Thanks!it works very well for me
Which kind of software do you use to see both front and rear camera images?Thank you very much..You are Super ..Both front and back camera logo and date REMOVED...cheers Sir
What I have done is to put a pendulum switch on the yellow ACC cable, so when I want to record always in parking I activate the switch, when I want to record only time lapse with the front camera or to work normally I deactivate the switch.Hi!
I have been using the firm 1.0.13ww-nopasaran-2022.07.05_LOGO_DATE_FREE_v2 since August
It is quite stable and has never crashed.
Do you know if this firmware (or any other firmware) allows the front and rear cameras to keep recording in parking mode?
The stock version when entering parking mode only records through the front camera. So a year ago I had to jumper the parking cable to the battery one and the car is recording 24 hours as if it were moving.
I don't like this because the camera is always recording at maximum resolution for 24 hours and it gets hot. And also, the 256GB card that it uses has capacity for about 12 hours of recording. But it is the only way I have found to keep recording both cameras when the car is parked.
Thanks!
I think firmware 10 or 11 did it and then they changed it because recording with both front and rear cameras in time lapse also made the camera warm up. try those firmwares.Maybe I didn't explain it well.
I always want to record with both cameras: when I'm driving with high resolution. And when it is parked, with low resolution or in time lapse mode.
The stock firmware, when camera enters into parking mode, disables the rear camera.
My solution has been to connect the parking mode cable (+Acc) to the battery cable (+Bat). So it never goes into parking mode and thus records with both cameras. Dash thinks I'm driving 24/7
What I'm looking for is some firmware version that, in parking mode, continues recording with both cameras so I put the electrical connections back as they should be: with the +Batt to the battery and the +Acc to the engine on signal so that the parking mode is detected again.
thank you!
@lisabon_Q3 , do you have a modified firmware which was shared by this person on 4pda?There is such a firmware, on the 4pda forum, user h45242 made it. Here is the list of changes:
system:
+ftp enabled
+telnet enabled
DVR:
+seat reservation for Normal increased from 58% to 75%
+Event seat reservation reduced from 22% to 11%
+Parking space reservation reduced from 13% to 7%
+bitrate 30Mb/s increased to 35Mb/s
1.0.12ww-nopasaran-2022.06.22.zip
drive.google.com
seems that he did a custom firmware based on 1.0.10ww which can increase normal seat reservation to either 90% and 98%, which is useful if I need to go for long distance journey.
do you possibly have updates cause links on 4pda forum don't work70mai_1.0.10ww_custom.zip
drive.google.com
No, this is the latest version of this modification. The author has not updated his mod.do you possibly have updates cause links on 4pda forum don't work
Sorry I see that there are other version of this mode in 4pda of this user but I can’t get them, can you help me ?No, this is the latest version of this modification. The author has not updated his mod.
Thank you so much, this is better right ?1.0.19ww-nopasaran-2023.05.23.zip
drive.google.com
Hello, everybody..
I'm fresh owner of A800S dashcam and I would like to use custom firmware, all the links I tried are not working, can please somebody post a working link with lasts version of custom firmware without 70mai logo?
Thank you in advance!
Testing A800S | A800S | 5 | ||
A800S Recording Parking Surveillance Video when leaving and arriving the car. | A800S | 3 | ||
M | Custom firmware now available for 70mai A800S | A800S | 0 | |
M | How to flash custom firmware on A800S? | A800S | 0 | |
M | 70mai A800S custom firmware (tp increase bitrate?) | A800S | 1 |
