gt0138d
Hi everyone.
I joined the forum after looking high and low for a clue on what to do next.
Both a 70mai A810 with the hardwire kit. After running around a couple of times around the guy who said he will install it for me, I decided to do it myself. Wired the rear camera and it showed up on the display. I even rotated the picture so that it showed up straight. Then, I pressed a few buttons and connected the dashcam to the hardwire kit USB C (until then, I had it connected to a powerbank). It didn't work.
I realized that I had installed the fuses in the Fuse Tap adapter incorrectly as even the Hazard lights (which was in parallel to this fuse) was not working. After switching, the lights are working but the dashcam did not turn on.
After that, the dashcam has not powered up when I plugged it into the cigarette lighter provide, directly in the car USB A, and in the same powerbank.
Is it bricked? There is a tiny hole next to the power button. Is there a way to reset this to bring it back to life? Need your inputs as I found nothing so far everywhere I searched until I ended up in this forum.
