Absolutely impossible to connect to wifi network with sta.conf
Ch-Flores
Spain
Hi guys!
I try to make a connection through the sta.conf file following the indications that are found in different places:
##### Wifi configuration file ##########################################
# SSID
SSID=PM2.5-5G
# Password
PASSWORD=1234567890
# Device Name
DEVICE_NAME=xiaoyi-1
# Country Code
COUNTRY_CODE=US
Specifically, I'm following here
Everything works ok and I can connect to the network created in my smart phone, the problem is that this version of the firm is 1.3, if I install the latest version 1.10 in my camera and add the same file in the root of the SD, there is no connection, it stays a few minutes trying to connect until it locks and turns off the screen, having to remove the battery to restart.
Can someone help me to move forward with this question? Thanks!
I have the same problem... can anybody help us??
You can connect to the router with a script by changing the firmware, which is available to run.
