I run 2x A119 Mini 2. 2K is all you really need, imo.
I also prefer the 2K (1440P) 60FPS over 4K 30fps.
The footage is much smoother and more frames makes is much lest "Ghosty" looking and really helps when u need to slow down the footage, go frame by frame to see every detail and finite move.
Also, consider, 4K video files are much much larger, and require higher end, more modern hardware to play back.
The cop/court room computer you need to send footage to when something happens, they be lucky to even have a 720p screen to watch it on, let alone be able to play 4K video (unless they have 3rd party player installed like VLC, which is often not allowed on Government IT systems.)
Why pay a place like Best Buy to install?? They do car audio, not dash cams.
Second, it often just teens who work there that know get little training and have no real experience.
You would be better off doing things your self.
For these basic dashcams, it litteraly is just stick it to the Windshield, and plug it in to the usb power adapter, that goes in your cig lighter port. Done.
It is not hard to just run a cable to the back if u have a 2ch system, and find places to tuck it under, like trim, Viofo cams even come with a trim pry tool.
The hardwire style kits, that is where it gets more advanced, but I would not recommend that to a beginner and for sure not until you at least test out your chosen dash cam model for a while first, before comiting to a more permanent and invasive installation. I have run my dash cams vis the cig port since 2016. But i do not care about it running all the time, Parking Mode, and it using the car battery when car is off.
