Can one of you possibly help me with my T Power Plus Alpha? I've been tinkering with it for a week and am not sure if I've received a bad unit. It seems to work fine when powered by the cigar power jack. However, I've been unable to get the hard wiring cables working. I have correctly identified appropriate fuses with a multimeter. I've grounded the unit and wired in the B+ wire. However, plugging in the ACC to the unit causes it to turn itself off - even when the other end of the cable is NOT wired into the fuse box. I have tried multiple different fuses (low 5A, 25A) with and without using an add-a-circuit. The Alpha charges from B+ cable and delivers power to my dashcam (Blackvue 650), but as soon as I plug in the ACC cable, the Alpha shuts off and stops delivering power to the camera. Again, whether or not the ACC wire is actually connected to anything.
Thanks
