QVIA AR790 Dual Camera: No Bluetooth light & will not connect.
I had AR790 installed 2 years back and it was working OK. Now it has stopped working and I would like help to fix it.
I had two problems:
Problem 1: My car is a Volvo XC70 hatch back and most of the time when I open the booth door, the second camera stopped working. I thought it was the strain on the connector of the cable to the rear camera. I had to have several attempt to reconnect and it finally worked.
Problem 2: My car battery needed changing. When my old battery was poor, the steady state blue light (Left hand side light), would turn red. ) hen this happened, I would lose blue tooth connection (Middle light: turn from blue to red). I had a new car battery installed recently and all the three light would go blue and everything was OK. One day, I had to open the hatchback door and that’s when the second problem occurred. I will not get the blue light for Bluetooth.
I have formatted the SD Card on several occasions. I have taken both the cameras out for over 24 hours hoping to reset any inherent fault.
He power supply is OK i.e. Un -switched Live is OK and the Switched Live is OK. Earth is OK. (Continuity is OK).
Is there any means of HARD resetting of the camera?
How do i do a factory default reset.
Is there any way of testing front camera as stand alone?
Likewise, how do i test second camera alone?
Is there anyone who can help me? I have looked at YouTube, but no joy.
I would like some help. Thank you for your time reading this article.
I had two problems:
