RedFord
I just installed my cam with the 3 wire power and the parking mode only seems to stay on for a few minutes after I turn off the truck or accessory. The cam turns on and starts recording when I turn on the truck. I have the red wire into constant power and used micro2 fuse taps for the fuse block at the passenger foot well. The power cutoff switch on the three wire is set at 12.4v.
This is on a 2019 F150 so perhaps the battery control module on the truck is shutting down any power drain after a short time?
Is the rec button supposed to flash then entire time it stays in parking mode? Right now when I shut the truck off the power button will start to flash after a short while, and then it will turn solid to recording if I open and slam the door. It only does this for a couple minutes though and then the whole camera shuts down.
Here are all the settings that I have
Resolution: 2560x1440P, 30FPS
Bitrate: High
Loop Recording: 3 minutes
Video Format: MP4
EV Exposure: +0.0
WDR: Off
Parking Mode: AutoEventDetection
ParkingG-Sensor: High Sensitivity
ParkingMotionDetection: Middle Sensitivity
Time-Lapse Recording: Off
Motion Detection: Off
GPS: Off
Speed Unit: MPH
G-Sensor: Low Sensitivity
Date Stamp: On
GPS Info Stamp: Off
Camera Model Stamp: On
Record Audio: Off
Screen Saver: 1 Minute
Boot Delay: Off
LED: On
Date/Time: (Self Explanatory)
Time Zone: GMT-8
Language: (Self Explanatory)
Beep Sound: Off
Frequency: 60Hz (USA)
Image Rotation: Off
Format: (Self Explanatory)
Format Warning: Off
Default Settings: (Self Explanatory)
Car Number: (No number)
Custom Text Stamp: (No custom text)
Firmware Version: Current V1.03
Build: 20190911
Bitrate: High
Video Format: MP4
EV Exposure: +0.0
WDR: Off
GPS: Off
Speed Unit: MPH
Date Stamp: On
GPS Info Stamp: Off
Record Audio: Off
Boot Delay: Off
LED: On
Time Zone: GMT-8
Beep Sound: Off
Image Rotation: Off
Format Warning: Off
Build: 20190911
