AV out
I verified that you can use a standard audio cable (3.5mm on one end, two RCA on the other) to display video to a composite source. The white RCA connector is the video. Sorry, I did not test the red RCA, so I do not know if that is audio or not.
actually a "standard" audio cable (headphone to rca/phono) is wired the same. it's 3.5mm 3 conductor male on one end and the other end has 2 rca jacks, normally red and white to indicate right and left. standard 3.5mm headphones/earbuds use the same pinout as this cable.
As MTZ posted above the wiring sequence at the plug can vary so that the video signal is not the yellow cable, but you can switch the cables.
not all cables are wired the same so a link to whichever cable you bought would be helpful
I posted a link to the cable that is wired right and a nice length above:
https://www.amazon.com/gp/B0053T5OWC
I'm gonna try this for backup camera.
I don't care what rca cable has video as long as it has on one of them.
that might work OK if the back window of your vehicle is vertical (van, SUV, hatchback) but in a sedan or pickup truck it won't give you any better view than the rearview mirror since the trunk/boot or truck bed will still be in the way. the OEM backup camera in our highlander is aimed down so far, you can see the edge of the back bumper at the bottom of the frame. you can see the ground approx 1 foot away from the back bumper. if we had a hitch, you'd be able to see that too, so hooking up a trailer would be a piece of cake (assuming you already have the trailer tongue raised high enough).
This is not for Camry. Camry is gone to its new owner. πŸ˜‰
It's for RX300 so should work.
I may have to point the camera little down meaning it may not catch traffic lights.
I'm getting a foldable 4.3 LCD screen that I can put on the dashboard like this one that should be large enough to see what's behind the vehicle:
If dashcam AV out doesn't work as expected, I can always get a el 'cheapo license plate camera that can use the same LCD monitor so no harm in buying the monitor.
Almost hit a stroller yesterday.
I looked but still missed the short woman pushing stroller past other vehicle parked next to me.
I'm not sure if rear cam prevents it though as it can't see behind other vehicles parked next to me anyways but should help little bit.
with as steep as the back window is, you won't be able to see anything within a few feet of the bumper if the camera is mounted inside.
skip the license plate camera and get one of these for $19: https://www.amazon.com/gp/B00GOY9KWUit replaces one of your license plate lights (but still has a light) and gives a clean, factory look with no drilling and without covering up any of your license plate (which is usually illegal). you'd have to run wires up inside the door no matter what, so you might as well do it right. πŸ™‚
Hmm... so down angle is not that good due to glass reflection?
I need to borrow a portable DVD player or something to test that theory.
I'm not stuck on what camera to get.
The one you linked mentions specific model (RX300) so should be better looking install.
However, reviews mention it's not too wide and the red line indicators are not accurate.
I'll do some reading on that.
not due to glass reflection, simply due to the slope of the glass. put your mini or something with a screen up against the back glass, point it down, and see how it looks. maybe put something on the ground behind teh car as a reference point. you'll see what i mean.
