Retronerd
Hi Guys,
Had this camera on the shelf for a while as it doesn't boot just displays the Avinta splash logo screen but no more. Managed to connect to TX RX gnd on motherboard and can see boot info NT96650 SDK (see below)
Looks like it may have had a bad/wrong firmware update. Can't find any firmware for it. Anyone recommend firmware I can use or next steps to get it working?
NPT
Loader NT96650 Start ...
650DDR3_300_1024Mb 08/04/2015 09:13:22
RRRRRRMID=000000EFTYPE=00000040,SIZE=00000016
RFlsh
R
PL
RCPU/OCP/APB = 432/432/80 Mhz, DMA = 300 Mhz
Clk verify PASS
NT96650 SDK
Copyright (c) 2012 Novatek Microelectronic Corp.
Hello, World!
wcl:NvtMain() LINE=202 MACHINE_IO_CHIP=199
^Rwcl:NvtMain() LINE=203 BOARD1=0x21101DC6
^Rwcl:NvtMain() LINE=208
^R> ----------------------------------------------------------------
gsensor_open(),I2C_Slave_WAddr:0x4E I2C_Slave_RAddr:0x4F Mesage:MIRDA380
.................. Gensor_SystemPowerON:0
wcl:mir3da_close_interrupt() LINE=214
^RERR: mir3da init begin 2
wcl:gsensor_open() LINE=116
^Rwclx_InitIO() LINE=302
^Rwcl:NvtMain() LINE=249
^REnter DSC
bind - begin!
bind - end!
event loop - begin!
ERR:ramdsk_setParam() No Implement! uiEvt 1
[LOAD-FW]
Total Sections = 2
Section-01: Range[0x80000000~0x800B1000] Size=0x000B1000 (LOAD)
wcl:System_OnStrg_DownloadFW() LINE=1126 ....isUsePartLoadbEnablePartload=1
^RPL_begin
Section-02: Range[0x800B0C70~0x8046283C] Size=0x003B1BCC (LOAD)
PL_end
wcl:UserMainProc() LINE=353 MACHINE_IO_CHIP=199
^Rwcl:UserMainProc() LINE=354 BOARD1=0x 36
^Rwcl:UserMainProc() LINE=370
^R......................Battery ADC=1023 AccDet:2
LD VERISON: LD650
FW --- Daily Build: $Date: 12/09/24 6:56p $
ERRx_GetObject() [Dx] GetObject 00150001 failed
ERRll_setClockFreq() Target(4) freq can not be divided with no remainder! Result is 13500000Hz.
WRN:mi_isr() MI:Fifo overflow
ERRrvLCDState() state=0x06 not support!
[DOUT1]: device = [Display_LCD], state = [STOP], mode = [0x23, 480x320]
[DOUT2]: device = [N/A], lockdevice = [N/A]
ERRStore_OpenSection() Section not found, name: DEFAULT, op: 0x1
ERR:SectionRead_Header() HEADER open to read FAIL
wclisplay_ShowSplash() LINE=1460 uiFWUpdate=0
^RUI_ShowLogoFile: logo uiFileSize 22734
ERR:Ux_GetRootWindow() wnd not created
WRN:sdioHost_setBusClk() SDIO host0 : real clock (396694Hz) is not equal to desired (399000Hz)
wcl:UI_UpdateLogoFile() LINE=987
^Rwcl:UI_WriteLogoFileName() LINE=917 open file error
^Rwcl:Load_MenuInfo() LINE=165 uiFWUpdate=0
^Rwcl:Load_MenuInfo() LINE=169 uiFWUpdate=0
^Rwcl:SetBeep() LINE=3160 param=0
^Rmir3da_set_int_level val =0
MovieExe_OnStopPaking() GSENSOR_STATUS_PARKMODE_LIVE:0
wcl:irrx_open() LINE=140
^RMode {MOVIE} Open begin
MODE -1->2
wcl:MovieExe_OnOpen() LINE=794
^Rwcl:GetModeInfo() LINEERR:Init_AR0330M() Init_AR0330M...
ERR:Init_AR0330M() ^GOTPM v5
ERR:Init_AR0330M() ^GChip version is 0x2604
wcl:GetModeInfo() LINE MOVIE path33 = MOVIE!
MOVIE path66 = PHOTO!
MOVIE path77 = MOVIE\RO!
ERR:FileDB_SortBy() u32TotalFilesNum=0
ERR:ChgMode_AR0330M() ChgMode_AR0330M to 4...
wcl:GetModeInfo() LINEwcl:GetCmdTab() LINE Mode=319
wcl:GetModeInfo() LINEERR:AF_Open() #Register AF event table.
wcl:GetModeInfo() LINEwcl:GetModeInfo() LINEwcl:GetModeInfo() LINEwcl:GetModeInfo() LINEERR:IPL_SIEClkCBFlowC() SIEclk = 240000000
ERRre_open() PLL6 selected but not enabled...
wcl:GetModeInfo() LINEERR:IPL_SIESetCAVIG_FCB() CA VIG Setting not ready
ERR:AF_Tsk() #Entered AF_Tsk
