Hi, on most days, it seems my B-124 and B124-E get me plenty of hours of juice. Somedays, suddenly my DR-900S 2ch shuts off and when I check the power, it's 0%, even though I had quite a bit of juice that morning. So, when I go to charge it, it jumps to 2%, eventually 26% or so after 30 minutes. Then I disconnect it (turn B-124 off) then turn it back on and suddenly my battery app shows it's in the 70s%. This leads me to believe for some reason the B-124E isn't always being activated. I'm assuming the B124 is drawn from first, then once that's out, then drawing from the B-124E begins.
At first I thought it was my camera draining the juice too much, but seeing the difference from 20's% suddenly to 70s% (about 50% increase) tells me that one of the batteries was still charged but wasn't "detected" and so the camera shuts off.
Any ideas on how to fix?
edit: I noticed that after charging from the 76% tonight, it got stuck at 99% at wouldn't budge. So I reset the app, and my phone, still 99% and the charge light on the battery itself still is lit red. I changed the capacity in the app to 6,000 mah, saved, and it still showed 99%. I changed it back to 12,600 mah and suddenly it's 49%. Now it's charging (61%) and climbing. So odd!
