Invisible
- May 15, 2021
- London
- United Kingdom
- Car: Apeman C450A // Motorcycle: Blueskysea B1M
Hello,
I found out many solutions here but still remains one problem.
I hardwire the unit in tail light with both red and yellow cables so there will be no battery drainage.
I update the unit to the latest firmware (v001.20210129)
I format the SanDisk card with my pc using EaseUS partition master to Fat32.
Unit power on normal and the phone connects normally.
After formatting the card from APP the unit behaves abnormally.
LEDs keep on, the unit doesn't beep while on or off.
I disconnect and connect everything again, power the unit with a smaller (16GB) card with fresh firmware on and the unit behaves normally.
Is it an issue with the 128GB card?
The unit when formatting a card of 128GB is formating it in Fat32? I am asking because when I put the card on my PC the card was in exFat and doesn't make sense.
And a last technical question. The GPS antenna will be ok under-seat next to the unit or needs to be out looking at a "clear sky"?
