B1M exposure flickering
Nightstalker1993
Malaysia
Just bought a B1M and installed on my bike, few things to note out. Most obvious is the exposure flickering on the front camera. On the camera preview in the app it does not flicker when it is not recording but once it starts recording it will start to flicker like in the video. Rear camera is fine. Actual bit rate also seems low as the image isn't very clear for vehicles slightly further away and you can see blockiness in the sky and road. Can see the video below for the exposure issue. Also I read there is a new firmware 01092020? I'm currently using the 07072020 firmware which it shipped with and can't find the new firmware on the blueskysea website.
It looks like a engine-noise related problem! Give it a try to reroute the front camera cable or wrap the front camera with RF tape?
Ahh, makes sense as the wire is being routed above the ignition leads. I was thinking it could be the vibration causing it to go haywire. Then again I seem to recall that it happens even when the engine is not running, but I cannot confirm until next week when I get back from work. Will update then.
Any info on the new firmware though and does it improve the video quality?
