Thank you. That gives me a better idea.Length and depth are the same, height is about 50% extra, but the mount holds it further from the glass so it sort of takes more space.
They actually look quite similar, but the mount is very different, the B1W mount makes it nice for mounting just about anywhere, including on side windows, the B4K is really only suitable for traditional windscreen mounting on a sloping windscreen.Thank you. That gives me a better idea.
Yeah, I like the small size of the b1w and the mount. It sits closer to the window and blends in a bit more. I also remove my b1w from my car everyday. Not sure how sturdy the b4k mount is. Since the b4w sits a bit further away from the window do you notice any more glare from the window in the vids vs the b1w?They actually look quite similar, but the mount is very different, the B1W mount makes it nice for mounting just about anywhere, including on side windows, the B4K is really only suitable for traditional windscreen mounting on a sloping windscreen.
It is pretty good, but it takes a little force to take it off/on, not as easy as the B1W, and it seems to be held by friction rather than clipping in.Not sure how sturdy the b4k mount is.
No, only difference is that the raindrops are more in focus so more noticable, and if you have heater wires in your windscreen, they may be a bit more noticable too. It is a lot closer to the glass than a typical suction cup mount, just not B1W close.Since the b4w sits a bit further away from the window do you notice any more glare from the window in the vids vs the b1w?
The B4K mount has GPS in it and does add to the size somewhat because of that but it's still a fairly small package overall. There are smaller cams, but not giving true 4K at this price. You don't get what you don't pay for but this cam gives you a lot for your money, and at a low price tooTBH smaller then i originally had envisioned.
love to see these two camera mounted to see difference from the outsideThe B4K mount has GPS in it and does add to the size somewhat because of that but it's still a fairly small package overall. There are smaller cams, but not giving true 4K at this price. You don't get what you don't pay for but this cam gives you a lot for your money, and at a low price too
Oh dear, I was thinking of replacing my B1W which is mounted on the back with B4K, but after having a closer look I have realized that probably it will not fit... I'm driving a minivan (VW Sharan), so the back door window has minimal angle.B4K is really only suitable for traditional windscreen mounting on a sloping windscreen.
If you could make some photos of you setup - would appreciate that.mounted off the hatch frame, i use magnets to space them out
