snakecam42
Hey guys, thanks for all your help. It was determined that the shipping company caused issues.
As Phil said, the reset button might not do anything if you just press it shortly. Hold it down for 15 seconds.Have you tried the reset function?
Power to the cam, then using a straightened paper clip or similar, insert it into the hole marked "Reset" on the bottom of then cam and push in- you should feel a click. Hold the reset switch in for 15 seconds then release. Unpower then repower the cam.
If after that you're getting the same issue, unpower the cam, remove the sd card, then repower the cam and see what those results are.
These steps may solve the problem but will at least help with diagnostics if they don't.
Looks like its screen was faulty or the wrong firmware!Just got the B4K, and right out of the box it will start up normally, but then freeze and shut down after about 10-60 seconds. Multiple power supplies, multiple microSd cards, multiple resets, all with the same result. Any ideas? Anyone seen this before?
Should be okay with our supplied power adapter!Yes I am using the original power adapter
Try it again without plugging a memory card! I need to know if it was a card-related problem! If it happens again, it should be a faulty dash camera, need to replace it!The reset seems to prolong the operation of the camera to 2-3min, but then the same issue crops up
No problem with this firmware! Should be a loosened FPV inside the camera unit I think! Need to replace you with a new dash camera!Currently running V008. I'm thinking bad internal ram?
DM me your shipping address. I will send you a new camera unit!Hey estore009,
I tried it without the memory card. Same issue (frozen yellow screen and then shutdown), but it took alot longer to show up (~5min). I think you're right, something got bumped loose during shipping. Will work on getting this fixed. Thanks everyone!
