AnthonyH
I have the Vantrue S1 Pro Max dual dash cam fitted in my car, it was originally hard wired, however subsequently i have discovered that the hard wired kit I purchased was not compatibility with my modern SEAT Leon MHEV eTsi car and its sophisticated electronic system, It has taken me over six months before I made the discovery that the hard wired kit VP03 was not correct and it continually drained my car battery below its level of operation resulting in my having a flat battery on several occasions. I communicated with Vantrue over some time and discovered that the kit I should have purchased was the VP01 kit, although Vantrue could not be certain about its compatibility with my car.
As I only purchased this dash cam for parked mode at night as I park my car on a public road outside my home, I have tried everything from using the OBD kit but that also continually drained the car battery. My original professional installer has sadly passed and I have so far been quoted over 150 euros to refit the correct hard wired VP01 kit, but several local professional's have declined to work with the car due to its MHEV set up as they will not risk damaging any original cabling or connections.
Finally I thought about a battery pack I looked at the 70mai and to plug it into the car cigarette lighter socket as I know after testing it that once the ignition is off the power to that socket goes off too.
I have asked both Vantrue and 70mai if there is any issues with using this method and neither can give me a definitive answer, i have also contacted SEAT which was a waste of time.
Does anybody know if the 70mai battery pack is compatible with the Vantrue S1 Pro Max dash cam?
