Alexcrist
No offence, but I'm gonna trust the documentation from the manufacturers, and also the actual results that I also posted at the start. Ghosting all the way. Yes, they ARE distinct, sequential captures.
Wow that is quite a statement...That is not correct, even if some Sony documentation says it is! ............
Sony's original DOL-HDR information described it as "Quasi-Suimultneous":Do we have a valid reason not to trust Sony on how their own product works?
They are now trying to sell Clear HDR, which is truly simultaneous, so have changed their advertising.
- The Dual Sony Flagship Sensors support the underlying DOL-HDR technology on a hardware level, increasing video dynamic range by 4x to that of the conventional HDR algorithm. DOL-HDR This technology enables the quasi-simultaneous synthesis of long and short exposure frames, effectively preventing ghosting artifacts caused by movement.
Viofo did not explain DOL-HDR, they simply said:Or not to trust Viofo, who basically confirmed it, by posting the info?
Which was perfectly correct!Sony's official definitions of the two features, DOL HDR and Clear HDR, are as follows.
The other problem with Clear HDR is that although it has an extended dynamic range, its dynamic range is limited by the single exposure and the brighter parts of the image have different noise levels to the less bright areas since they are read with a different gain level, so you can get patches of image with extra noise/blur, and the joins can be noticeable. It is good for people who want to make traditional 24fps grainy video, with shutter speeds of 180° so that they get good levels of motion blur to hide the steps between frames. It is not so good for reading license plates.Clear HDR doesn't have a fast exposure, only dark and bright, so it does not freeze license plate text at night, it still has image blur.
You just now saw this, but didn't notice it before?I am very glad to report that Viofo took care of the extremely important stuff, like adding big-ass useless branding and logo over the video. Because that was the major thing that was missing.
Maybe check the memory card?More minor things were ignored, like bugs (the card format warning is still happily beeping at every boot, although I literally just formatted the card 3 times in the camera during the FW update).
This has been since the release of A229 Plus.It wasn't there before. I'm talking about this magnificent thing:
I don't include this. I don't need to be reminded when to format the memory card.About the card, maybe you didn't enable the format reminder in the settings?
Even "better", forcibly disabling settings that I explicitly configured and enabling crappy marketing watermarks. As I said, great way of showing what's important. Great job, Viofo, keep it up!This has been since the release of A229 Plus.
Are you holding your first DVR in your life?Even "better", forcibly disabling settings that I explicitly configured and enabling crappy marketing watermarks.
Where did you see rudeness?Again you are deeply wrong, my friend. Those are literally the only settings that were changed. Even the custom texts were preserved, they were just hidden/disabled. Everything else was intact.
But, by all means, you can continue being rude and aggressive for no reason.
I don’t work for Viofo, but I responded to your posts because I didn’t see the truth in them.By any chance, are you working for Viofo and you feel insulted by the honest truth?
With Viofo firmware updates, it is recommended to use the reset to default option in the setup after a firmware update, normally it is not necessary, but a few people had various issues with incorrect settings after the last set of firmwares, so definitely recommended. Not sure why they don't reset to default automatically, except that some people like you complain if they do, and normally it is not necessary. Seems like this time some configuration memory got moved around due to extra settings.Again you are deeply wrong, my friend. Those are literally the only settings that were changed. Even the custom texts were preserved, they were just hidden/disabled. Everything else was intact.
But, by all means, you can continue being rude and aggressive for no reason. By any chance, are you working for Viofo and you feel insulted by the honest truth? Probably not, but you certainly act like that.
He didn't initially mention anything about additional manual steps, he only later mentioned that, when I pointed out that he was wrong - again, just like with the format reminder option.Are you aware that after updating the firmware, all settings are reset to factory settings and if you need to,
then you must set the settings to the ones you need?
That's it! If that is wrong, it's again Viofo's fault. Not mine, I followed the official instructions. If they need additional steps and they can't/don't want to automate them, they need to be specified in a single place. So again, who's wrong making accusations here?How to update firmware:
Format the card first and then download the bin file to the the card and power the camera with card inserted.
I suggest that you use the "reset to defaults" option, since you don't appear to have followed the advice to use it yet, and maybe the format reminder will start working...I said the format reminder option is not working, Karagandinez said it does,
You don't need to leave the settings at default, just use the reset to default and then set it up as you wish.And how about anyone discussing the bugs I mentioned? Nobody cares about that, as usual, it's of course my mistake because I changed settings and didn't leave them at factory default. So it makes sense why Viofo craps all over them as well, because the buyers will keep buying, regardless of the crappy firmware.
