Dunning-Kruger effect in action.
Aperture will never have any effect on motion blur, from now until the end of time..
One thing it does effect is amount of light that that passes to the sensor, and to keep a constant EV (exposure) you must change one of the other variables which one does change motion blur.
Saying aperture causes motion blur is like saying if I press the throttle in my car the physical act of pressing the throttle down is what pushes the car forwards, when in reality the change to the throttle position causes a change to the rpm/load of the engine which actually drives the engine forward.
So no the throttle doesn’t make your car go any faster, your engine does.
The only thing that changes motion blur is shutter speed, fact, not up for debate.
The other two things you can change is ISO and/or aperture, neither have any effect on motion blur, they change how much light is able to pass to the sensor, and how much you boost the signal from the sensor.
if you wish to keep the same exposure then if you from say f/1.4 to f/4 that is 2 stops different, or we can say the f1.4 let’s in 4 times the amount of light at f/4
So your going to have an image that is 4 times darker than at f.4 original, so you can either boost the signal by adjust the ISO 2 stops, say from ISO400 to ISO1600, or if the shutter speed is at 1/60th going 2 stops would be 1/15th for the same exposure. Both ways compensates for the darker image.
So if your statement was true that aperture that controls the amount of motion blur then it would have this results in both ways of correcting the exposure, whether it be from ISO adjustment OR shutter speed adjustment.
The fact is that ISO will not change the imaged blur level captured, as it is only boosting the signal.
So in conclusion, aperture has no effect on motion blur, but can cause settings to change (I.e shutter speed) in compensation to get the same EV which will effect the change of motion blur, but if we had variable ISO it wouldn’t.
As I clearly said a DSLR can break the 180rule shutter rule, typically when the fps is say 30, you would expose for 1/60th of a second, so this will give you smooth looking footage which is nice on the eyes, but if you go for a 90 degree shutter angle where the frame is now open for 1/125th of a second your going to have more unnatural looking movement, but each frame within that 30fps will be less blurry at the expense of loosing a stop of light, which you would need to compensate for in one stop of ISO. You can go further to 45degree etc.
It’s a balance between being a series of photos that do not blend for when watching back a whole clip vs freeze framing to say grab a detail non blurred shot of a number plate.
If you have a fixed ISO film (not digital) then of course changing the aperture, then your only option is to adjust shutter speed to compensate, so a wide open lens (fast lens) would allow a faster shutter speed for the same exposure of a shut down lens which would require a slower shutter speed to get the same exposure.
