Oops, never got notification of your reply. Happen to stumble on it. No it not issue, in fact I can go 1 inch higher and it still within wiper range. No interference from mirror assembly and decal on top of window.
I will move it up, as I started to install the hardwire kit. If one follow the shift cable it takes you to a plug which bring it out to the engine compartment where my TIPEN (fuse box) and battery. I am waiting for parts, fuses, micro2 tap to complete the installed.
I can move the lens, so that it doesn't see the hood or anything else in the vehicle. I have been doing test and moved the camera by accident. I may even put it right behind the mirror. The hardwire kit plug is offset, so can do it, but not with acessory, as it straight plug which will be too much below the mirror housing to my liking.
Once I get it complete I drop a screen shot. Right now I am held up by parts that I didn't know it did not come with the hardwire kit. I have the back camera but will install it, once I finish the front. May even take a look at the IR unit.
So far, I am impress with the A129 Dual 4k by Viofo. No issue even though i am using cheap 32gb I borrow from one of my wyse camera. I have 256gb Scandisk on order, should arrive tomorrow.
I had Nextbase 522gw, return it, as they couldn't fix the issue, not sharp. Bad wifi on it and very buggy app.
