On the BlackVue product website the cables available for the B-124/B-124X/B-130X appear to be the same. I reviewed a B-124X back in 2019. I don't have it any longer so I can't check the cables in the box, but they appear to be the same.
The B-124/B-124X had a mode switch to (Cigarette/Off/Hardwire).
The B-130X only has an OFF/ON switch.
Even if the B-124/B-124X had the switch set to "Hardwire" and its charging power was provided by the cigarette lighter adapter cable, the presence of the third external contact (which is connected to ground on the charging cable) on XT60I-F connector would let the battery pack know that it should limit its charging amps to 5A.
Since the B-130X only has an "OFF/ON" switch, the B-130X relies on the charging cable connector being plugged into the battery pack's "DC In" charging port to have the third external contact when it's the cigarette lighter adapter power cable so the B-130X knows to limit its charging amps to 5A.
If you're using a cigarette lighter power cable supplied with the B-124, please make sure it does have the third external contact (just to make sure I'm not forgetting something). If you're using the B-124's hardwire charging cable, it should be the same as provided with the B-130X.
![1710351854697.png 1710351854697.png](https://dashcamtalk.com/forum/data/attachments/71/71117-92fb3ce5115086019ecebe8b3d08fa4a.jpg?hash=kvs85RFQhg)
