ajnuzzi
So I just got my blackvue battery installed and while it is working fine, I keep getting a low voltage error. The incoming voltage fluctuates between 9-14 volts. The amps never drop below 9amps and it appears to be working besides the error popping up every thirty seconds. Has anyone ever had this issue before? This is doing this while the truck (18 silverado) is running. I did check the ground connection as well as made sure I'm connected to a proper 10amp fuse. Should I just ignore this since it seems to be operating properly?
